Your basket is empty
Philips 21.5 INCH Monitor  IPS LED VGA DVI DP Speakers HA Pivot 100x
Quicklinx: BYJLWS00 Mfr#: 221S6QYMB/00
Select:
The Philips ergonomic AH-IPS LED display using 25% recycled materials and PVC, BFRfree housing is ideal for eco-friendly productivity.
Philips S-line 221S6QYMB - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Power Consumption (On mode)
16.96 W
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
14 ms (typical); 5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Textured black with black stand
51.1 cm x 22.7 cm x 48.3 cm
4.9 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV GS, BSMI, GOST, SASO, SEMKO, TUV Ergo, DDC/CI, RoHS, WEEE, TCO Displays 6.0, cETLus
Display Type
16.96 W
Diagonal Size
22"
Viewable Size
21.5"
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
Controls & Adjustments
Volume
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, sRGB colour management, Eco-Mode, SmartContrast, SmartImage, Smart Ergo base, Flicker Free technology, BFR/PVC-free, Mercury free
51.1 cm x 22.7 cm x 48.3 cm - with stand
4.9 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
DisplayPort , DVI-D (HDCP) , VGA , Audio line-in , Headphones
Mechanical
Tilt Angle
-5/+20
Swivel Angle
150
Rotation Angle
90
Height Adjustment
110 mm
Flat Panel Mount Interface
100 x 100 mm
MTBF
30,000 hour(s)
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.2 Watt
Included Software
Philips SmartControl Premium
Apple MacOS X, Microsoft Windows 7 / 8 / 8.1
Dimensions & Weight Details
With stand - width: 51.1 cm - depth: 22.7 cm - height: 48.3 cm - weight: 4.9 kg , Without stand - width: 51.1 cm - depth: 5.2 cm - height: 31.9 cm - weight: 3.1 kg
ENERGY STAR Certified
20 - 80%
BYJL C2G 1m DVI-D™ M/M Dual Link Digital Video Cable In Stock £6.63
BYJL C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £7.42
BYJL C2G 5m DVI-D™ M/M Dual Link Digital Video Cable In Stock £10.15
BYJL C2G 2M DVI D M/F DIGITAL VIDEO EXT CBL In Stock £8.29
BYJL C2G Velocity™ DVI-D™ Male to HDMI® Female Inline Adapter In Stock £5.00
BYJL C2G Velocity™ DVI-D™ Female to HDMI® Male Inline Adapter In Stock £7.11
BYJL C2G 2m HDMI to DVI-D Digital Video Cable In Stock £7.03
BYJL C2G Pro DVI-D to VGA Converter - Video converter - Black In Stock £47.00
