Product
Philips 21.5" Brilliance LED backlight LCD monitor PowerSensor Silve
Quicklinx: 8LN9WS00 Mfr#: 221B3LPCS/02
Eco-friendly, EPEAT Gold certified Philips Business Line 221B3 LED display with intelligent PowerSensor detects user presence and adjusts power consumption saving up to 80% of energy bills! PowerSensor is a built-in 'people sensor' that transmits and receives harmless infrared signals to determine if user is present and automatically reduces monitor brightness when user steps away from the desk, cutting energy costs by up to 80-percent and prolonging monitor life. Philips' monitor with LED backlighting is free of mercury content, one of the most toxic natural substances which affect humans and animals. This allows for an eco-friendly display throughout its lifecycle, from manufacturing to disposal.
  • PowerSensor
  • LED technology
    White LED is solid state devices which light up to full, consistent brightness faster, saving startup time. LED is free from mercury content which allows for eco-friendly recycling and disposal process. LED allows for better dimming control of LCD backlight, resulting in super high contrast ratio. It also gives superior color reproduction thanks to consistent brightness across the screen.
  • Mercury free
  • Zero switch
    At the touch of a single on/off button which is conveniently located at the back of the monitor, the monitors' energy consumption is reduced to zero. In the off mode, the monitor is completely cut off from AC power and thereby reducing your carbon footprint even further.
  • EPEAT Gold
    Philips EPEAT Gold certified monitor ensures protection for human health and the environment, and is a highly energy efficient ensuring low emission of climate changing green house gases.
  • SmartImage
    SmartImage is an exclusive leading edge Philips technology that analyzes the content displayed on your screen and gives you optimized display performance. This user-friendly interface allows you to select various modes like office, image, entertainment, economy etc., to fit the application in use. Based on the selection, SmartImage dynamically optimizes the contrast, color saturation and sharpness of images and videos for ultimate display performance. The economy mode option offers you major power savings. All in real time with the press of a single button!
  • 2 ports USB 2.0 hub
    USB hub allows user to conveniently connect their plug and play multimedia devices such as USB memory devices, camera, portable HDD, web camera, PDA, printer and many other devices which have USB connection available. The conveniently located USB 2.0 hub on the monitor allows USB 2.0 signals to pass through to the computer.
  • SmartTouch controls
    SmartTouch controls are intelligent, touch sensitive icons that replace protruding buttons. Responding to your lightest touch, SmartTouch controls, for example, power up your monitor or brighten and sharpen your display with SmartImage Lite. When activated, SmartTouch icons glow to indicate that your commands have been implemented.
  • Height adjustment
    The compact ergo base is a 'people-friendly' Philips monitor base that tilts, swivels and is height adjustable so each user can position the monitor for maximum viewing comfort and efficiency.
Philips Brilliance B-line 221B3LPCS - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
USB Hub
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Textured silver
50.7 cm x 22.7 cm x 48 cm
5.3 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, UL, TUV GS, BSMI, GOST, cUL, SEMKO, TUV Ergo, DDC/CI, RoHS, TCO Displays 5.1
3 years warranty
Display Type
Diagonal Size
21.5"
Built-in Devices
USB Hub
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
83 kHz
Horizontal Viewing Angle
176
Vertical Viewing Angle
170
Backlight Technology
WLED
Controls & Adjustments
Volume
OSD Languages
Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish
Sync on Green, sRGB colour management, Compact Ergo Base, HDCP, Super Ergo base, PowerSensor, SmartTouch, SmartContrast, SmartImage
Textured silver
50.7 cm x 22.7 cm x 48 cm - with stand
5.3 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1.5 Watt
VGA , DVI-D (HDCP) , Headphones , 2 x USB , Audio line-in
Mechanical
Tilt Angle
-5/+20
Swivel Angle
130
Height Adjustment
110 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), wall mountable
MTBF
30,000 hour(s)
Power Supply
Internal
17.8 Watt
Power Consumption Stand by / Sleep
0.1 Watt
Dimensions & Weight Details
With stand - width: 50.7 cm - depth: 22.7 cm - height: 48 cm - weight: 5.3 kg , Without stand - width: 50.7 cm - depth: 5.9 cm - height: 32.3 cm - weight: 3.4 kg
ENERGY STAR Certified
Limited warranty - 3 years
20 - 80%
8LN9 C2G 2m USB 2.0 A/B Cable - Black In Stock £3.82
8LN9 C2G 5m USB 2.0 A/B Cable - Black In Stock £4.96
8LN9 C2G 4-Port USB 2.0 Aluminum Hub In Stock £14.78
8LN9 C2G 12m USB 2.0 A/A Active Extension Cable In Stock £16.17
8LN9 C2G USB Superbooster Extender Kit In Stock £36.55
8LN9 C2G Trulink® USB to Gigabit Ethernet Adapter In Stock £22.60
8LN9 C2G USB to HDMI Adapter with Audio Up To 1080p In Stock £42.30
