Philips 21.5" 1920x1080 5ms VGA DVI-D Black Monitor
Quicklinx: 98JHWS00 Mfr#: 223V5LSB/00
Diagonal Size: 21.5in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: None
Interfaces: DVI, VGA (HD-15)
£70.60 ex VAT
£84.72 inc VAT
Great LED images in vivid colours
Enjoy vivid LED pictures on this Philips display. Equipped with SmartControl lite, it's a great choice!
SmartContrast for rich black details
SmartContrast is a Philips technology that analyses the contents you are displaying, automatically adjusting colours and controlling backlight intensity to dynamically enhance contrast for the best digital images and videos or when playing games where dark hues are displayed. When Economy mode is selected, contrast is adjusted and backlighting fine-tuned for just-right display of everyday office applications and lower power consumption.
16:9 Full HD display for the best viewing experience
The Full HD screen has the widescreen resolution of 1920 x 1080p. This is the highest resolution of HD sources for the best possible picture quality. It is fully future-proof as it supports 1080p signals from all sources, including the most recent sources such as Blu-ray and advanced HD game consoles. The signal processing is extensively upgraded to support this much higher signal quality and resolution. It produces brilliant flicker-free progressive scan pictures with superb brightness and colours.
LED technology for vivid colours
White LED's are solid state devices which light up to full, consistent brightness faster saving startup time. LED's are free from mercury content, which allows for eco-friendly recycling and disposal process. LED's allow for better dimming control of the LCD backlight, resulting in a super high contrast ratio. It also gives superior colour reproduction thanks to consistent brightness across the screen.
Easy display performance tuning with SmartControl Lite
SmartControl Lite is the next generation 3D icon-based GUI monitor control software. This allows the user to fine-tune most parameters of the monitor like Colour, Brightness, screen calibration, Multimedia, ID management etc with the mouse.
Mercury Free eco-friendly display
Philips monitors with LED backlighting are free of Mercury content, one of the most toxic natural substances, which affects humans and animals. This allows for an eco-friendly display throughout its life-cycle, from manufacturing to disposal.
  • SmartControl Lite
    SmartControl Lite is the next generation 3D icon-based GUI monitor control software. This allows the user to fine-tune most parameters of the monitor like Colour, Brightness, screen calibration, Multimedia, ID management etc. with the mouse.
  • SmartContrast
  • Mercury Free
    Philips monitors with LED backlighting are free from Mercury, one of the most toxic natural substances, which affects humans and animals. This reduces the environmental impact of the display throughout its lifecycle, from manufacturing to disposal.
  • 16:9 Full HD display
    Picture quality matters. Regular displays deliver quality, but you expect more. This display features enhanced Full HD 1920 x 1080 resolution. With Full HD for crisp detail paired with high brightness, incredible contrast and realistic colours, expect a true-to-life picture.
Philips V-line 223V5LSB - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 10000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Matte black, textured black
50.3 cm x 21.3 cm x 37.6 cm
2.61 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
Plug and Play, FCC Class B certified, TUV, BSMI, GOST, SASO, SEMKO, PSB, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE
Display Type
Diagonal Size
21.5"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, sRGB colour management, HDCP, SmartContrast, 4:3 in Wide
50.3 cm x 21.3 cm x 37.6 cm - with stand
2.61 kg
VGA , DVI-D
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
MTBF
30,000 hour(s)
Power Supply
Internal
15.64 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Philips SmartControl Lite
Apple MacOS, Microsoft Windows 7, Windows 8
Dimensions & Weight Details
With stand - width: 50.3 cm - depth: 21.3 cm - height: 37.6 cm - weight: 2.61 kg , Without stand - width: 50.3 cm - depth: 5 cm - height: 31.6 cm - weight: 2.35 kg
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
20 - 80%
Philips 21.5 Bundle deal on Philips 21.5" 1920x1080 5ms VGA DVI-D Black Monitor
£169.77
Accessories (4)
98JH StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £112.28
98JH StarTech.com Articulating Monitor Arm In Stock £104.51
98JH StarTech.com Dual Monitor Stand In Stock £70.92
98JH StarTech.com Cubicle Monitor Hanger In Stock £45.76
Other bundles (5)
98JH C2G 1m DVI-D™ M/M Dual Link Digital Video Cable In Stock £8.22
98JH C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £9.52
98JH C2G 5m DVI-D™ M/M Dual Link Digital Video Cable In Stock £17.45
98JH C2G Velocity™ DVI-D™ Male to HDMI® Female Inline Adapter In Stock £5.00
98JH C2G 2m HDMI to DVI-D Digital Video Cable In Stock £8.94
Response Time: 5ms
Speakers: None
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: Philips
Price Range Ex VAT: 50 - 100
