Philips 200V4QSBR/00 20" 1920x1080 DVI VGA Monitor
Quicklinx: BYZFWS00 Mfr#: 200V4QSBR/00
Diagonal Size: 20in
Max Resolution: 1920 x 1080
Response Time: 20ms
Interfaces: DVI, VGA (HD-15)
£64.87 ex VAT
£77.84 inc VAT
Enjoy vibrant MVA LED pictures with this attractive, glossy design display. Equipped with SmartControl lite, it’s a great choice!
Philips V-line 200V4QSBR - LED monitor - Full HD (1080p) - 20"
LED-backlit LCD monitor - 20"
Panel Type
MVA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.22 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 10000000:1 (dynamic)
Response Time
8 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Black gloss textured
47.9 cm x 20.1 cm x 36.9 cm
2.72 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV, CCC, PSB, DDC/CI, RoHS, Lead-Free, ETL, ISO 9241-307, WEEE, CECP, CEL, EPA, China RoHS
Display Type
Diagonal Size
20"
Viewable Size
19.53"
Panel Type
MVA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.22 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
8 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, sRGB colour management, SmartResponse, SmartContrast, Mercury free
47.9 cm x 20.1 cm x 36.9 cm - with stand
2.72 kg
VGA , DVI-D (HDCP)
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
MTBF
30,000 hour(s)
Power Supply
Internal
15.22 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Apple MacOS X, Microsoft Windows 7, Windows 8.1
Dimensions & Weight Details
With stand - width: 47.9 cm - depth: 20.1 cm - height: 36.9 cm - weight: 2.72 kg , Without stand - width: 47.9 cm - depth: 4.8 cm - height: 29.9 cm - weight: 2.39 kg
ENERGY STAR Certified
20 - 80%
Philips 200V4QSBR/00 20 Bundle deal on Philips 200V4QSBR/00 20" 1920x1080 DVI VGA Monitor
£164.04
BYZF C2G 1m DVI-D™ M/M Dual Link Digital Video Cable In Stock £7.89
BYZF C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £9.23
BYZF C2G 5m DVI-D™ M/M Dual Link Digital Video Cable In Stock £16.77
BYZF C2G Velocity™ DVI-D™ Male to HDMI® Female Inline Adapter In Stock £5.00
BYZF C2G Velocity™ DVI-D™ Female to HDMI® Male Inline Adapter In Stock £7.52
BYZF C2G 2m HDMI to DVI-D Digital Video Cable In Stock £8.58
Diagonal Size: 20in
Response Time: 20ms
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: Philips
Price Range Ex VAT: 50 - 100
