Philips 20" LED 1600 x 900 Monitor 16:9 600:1 Vesa Black Bezel
Quicklinx: 98XYWS00 Mfr#: 203V5LSB26/10
Diagonal Size: 19.5in
Max Resolution: 1600 x 900
Response Time: 5ms
Speakers: None
Interfaces: VGA (HD-15)
17 in stock
£58.32 ex VAT
£69.98 inc VAT
Enjoy vivid LED pictures on this Philips display. It equipped with SmartControl lite, it's a great choice!
  • Mercury Free eco-friendly display
    Philips monitors with LED backlighting are free from Mercury, one of the most toxic natural substances, which affects humans and animals. This reduces the environmental impact of the display throughout its lifecycle, from manufacturing to disposal.
  • Easy display performance tuning with SmartControl Lite
    SmartControl Lite is the next generation 3D icon-based GUI monitor control software. This allows the user to fine-tune most parameters of the monitor like Colour, Brightness, screen calibration, Multimedia, ID management etc. with the mouse.
Philips V-line 203V5LSB26 - LED monitor - 19.5"
LED-backlit LCD monitor - 19.5"
Aspect Ratio
16:9
Native Resolution
1600 x 900 at 60 Hz
Pixel Pitch
0.26 mm
Brightness
200 cd/m²
Contrast Ratio
600:1 / 10000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
VGA
Display Position Adjustments
Tilt
Textured black, black hairline
46.5 cm x 17 cm x 34.5 cm
2.33 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
Plug and Play, FCC Class B certified, BSMI, GOST, SEMKO, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE
Display Type
Diagonal Size
19.5"
Aspect Ratio
16:9
Native Resolution
1600 x 900 at 60 Hz
Pixel Pitch
0.26 mm
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
90
Vertical Viewing Angle
50
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, sRGB colour management, SmartContrast
46.5 cm x 17 cm x 34.5 cm - with stand
2.33 kg
VGA
Mechanical
Tilt
Tilt Angle
-3/+10
VESA Mounting Interface
100 x 100 mm
MTBF
30,000 hour(s)
Included Software
Philips SmartControl Lite
Apple MacOS X, Microsoft Windows 7, Windows 8
Dimensions & Weight Details
With stand - width: 46.5 cm - depth: 17 cm - height: 34.5 cm - weight: 2.33 kg , Without stand - width: 46.5 cm - depth: 4.8 cm - height: 28.5 cm - weight: 2.03 kg
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
20 - 80%
98XY C2G 2m DVI-A Male to HD15 VGA Male Analogue Video Cable In Stock £11.46
98XY C2G VGA to Composite PC-TV Video Adapter In Stock £33.26
Response Time: 5ms
Speakers: None
Brand: Philips
Price Range Ex VAT: 50 - 100
