Philips 19S4QAB/00 19" 1280x1024 DVI VGA Monitor
Quicklinx: BYPWWS00 Mfr#: 19S4QAB/00
Diagonal Size: 19in
Max Resolution: 1280 x 1024
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DVI, VGA (HD-15)
Select:
£111.67 ex VAT
£134.00 inc VAT
The Philips display using 25% recycled materials and PVC, BFR-free housing is ideal for eco-friendly productivity.
  • SmartImage pre-sets for easy optimised image settings
    SmartImage is an exclusive leading edge Philips technology that analyses the content displayed on your screen and optimises your display performance. This user-friendly interface allows you to select various modes, like Office, Photo, Movie, Game, Economy etc., to fit the application in use. Based on the selection, SmartImage dynamically optimises the contrast, colour saturation and sharpness of images and videos for ultimate display performance. The Economy mode option offers you major power savings. All in real time at the touch of a single button!
  • IPS-ADS wide-view technology for image and colour accuracy
    IPS-ADS displays use an advanced technology that gives you extra-wide viewing angles of 178/178 degrees, making it possible to view the display from almost any angle. Unlike standard TN panels, IPS-ADS displays give you remarkably crisp images with vivid colours, making them ideal not only for Photos, movies and web browsing, but also for professional applications that demand colour accuracy and consistent brightness at all times.
  • Less eye fatigue with Flicker-Free technology
    Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-Free technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing.
Philips S-line 19S4QAB - LED monitor - 19"
LED-backlit LCD monitor - 19"
Panel Type
IPS
Aspect Ratio
5:4
Native Resolution
1280 x 1024 at 60 Hz
Pixel Pitch
0.293 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
14 ms (typical); 5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Textured black
40.4 cm x 19.4 cm x 41.8 cm
3.2 kg
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV GS, C-Tick, BSMI, GS, SEMKO, CCC, TUV Ergo, PSB, DDC/CI, WEEE, CECP, cETLus
Display Type
Diagonal Size
19"
Panel Type
IPS
Aspect Ratio
5:4
Native Resolution
Pixel Pitch
0.293 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, sRGB colour management, SmartResponse, SmartContrast, SmartImage, SmartPower, Flicker Safe
Textured black
40.4 cm x 19.4 cm x 41.8 cm - with stand
3.2 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1.5 Watt
VGA , DVI-D (HDCP) , Audio line-in , Headphones
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
MTBF
70,000 hour(s)
Power Supply
Internal
16.2 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Apple MacOS X, Microsoft Windows 7, Windows 8, Windows 8.1
Dimensions & Weight Details
With stand - width: 40.4 cm - depth: 19.4 cm - height: 41.8 cm - weight: 3.2 kg , Without stand - width: 40.4 cm - depth: 6.1 cm - height: 34.6 cm - weight: 2.8 kg
TCO Certified
ENERGY STAR Certified
BYPW C2G 1m DVI-D™ M/M Dual Link Digital Video Cable In Stock £7.55
BYPW C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £8.83
BYPW C2G Velocity™ DVI-D™ Male to HDMI® Female Inline Adapter In Stock £5.00
BYPW C2G 2m HDMI to DVI-D Digital Video Cable In Stock £8.34
Diagonal Size: 19in
Response Time: 5ms
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: Philips
Price Range Ex VAT: 100 - 150
