Philips 193V5LSB2 18.5" 1366x768 5ms VGA LED Black Monitor
PRICE DROP!
Clearance
Last Few Remaining
Price Drop
Quicklinx: 8VPJWS00 Mfr#: 193V5LSB2/10
Diagonal Size: 18.5in
Max Resolution: 1366 x 768
Response Time: 5ms
Speakers: None
Interfaces: VGA (HD-15)
£48.32 ex VAT
£57.98 inc VAT
Enjoy vivid LED pictures on this Philips display. Equipped with SmartControl lite, it's a great choice!
  • Mercury Free
    Philips monitors with LED backlighting are free from Mercury, one of the most toxic natural substances, which affects humans and animals. This reduces the environmental impact of the display throughout its lifecycle, from manufacturing to disposal.
  • SmartControl Lite
    SmartControl Lite is the next generation 3D icon-based GUI monitor control software. This allows the user to fine-tune most parameters of the monitor like Colour, Brightness, screen calibration, Multimedia, ID management etc. with the mouse.
  • SmartContrast
    SmartContrast is a Philips technology that analyses the contents you are displaying, automatically adjusting colours and controlling backlight intensity to dynamically enhance contrast for the best digital images and videos or when playing games where dark hues are displayed. When Economy mode is selected, contrast is adjusted and backlighting fine-tuned for just-right display of everyday office applications and lower power consumption.
Philips V-line 193V5LSB2 - LED monitor - 18.5"
LED-backlit LCD monitor - 18.5"
Aspect Ratio
16:9
Native Resolution
1366 x 768 at 60 Hz
Pixel Pitch
0.3 mm
Brightness
200 cd/m²
Contrast Ratio
700:1 / 10000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
VGA
Display Position Adjustments
Tilt
Textured black, black hairline
43.7 cm x 17 cm x 33.8 cm
2.15 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
Plug and Play, FCC Class B certified, TUV, BSMI, GOST, SASO, SEMKO, PSB, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE
Display Type
Diagonal Size
18.5"
Aspect Ratio
16:9
Native Resolution
1366 x 768 at 60 Hz
Pixel Pitch
0.3 mm
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, sRGB colour management, SmartContrast
43.7 cm x 17 cm x 33.8 cm - with stand
2.15 kg
VGA
Mechanical
Tilt
Tilt Angle
-3/+10
VESA Mounting Interface
100 x 100 mm
MTBF
30,000 hour(s)
Power Supply
Internal
8.76 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Included Software
Philips SmartControl Lite
Apple MacOS, Microsoft Windows 7, Windows 8
Dimensions & Weight Details
With stand - width: 43.7 cm - depth: 17 cm - height: 33.8 cm - weight: 2.15 kg , Without stand - width: 43.7 cm - depth: 4.8 cm - height: 27.3 cm - weight: 1.94 kg
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
20 - 80%
Philips 193V5LSB2 18.5 Bundle deal on Philips 193V5LSB2 18.5" 1366x768 5ms VGA LED Black Monitor
£147.49
8VPJ C2G 2M HD15 M/M UXGA MONITOR CBL W/ FE In Stock £10.00
8VPJ C2G 2m DVI-A Male to HD15 VGA Male Analogue Video Cable In Stock £11.22
8VPJ C2G VGA to Composite PC-TV Video Adapter In Stock £32.58
Response Time: 5ms
Speakers: None
Brand: Philips
Price Range Ex VAT: 0 - 50
