Philips 19" LCD Monitor LED Backlight 1280 x 1024 5:4 Black Bezel
Quicklinx: 98X6WS00 Mfr#: 19B4LCB5/00
The Philips LED display using 25% recycled materials and PVC, BFR free housing is ideal for eco-friendly productivity.
  • LED technology
    White LEDs are solid state devices which light up to full, consistent brightness faster saving startup time. LEDs are free from mercury content which allows for eco-friendly recycling and disposal process. LEDs allow for better dimming control of LCD backlight, resulting in super high contrast ratio. It also gives superior color reproduction thanks to consistent brightness across the screen.
  • SmartErgoBase
    The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The base's people-friendly height, swivel, tilt and rotation angle adjustments position the monitor for maximum comfort that can ease the physical strains of a long workday; cable management reduces cable clutter and keeps the workspace neat and professional.
  • Low bezel-to-table height
    The Philips monitor, thanks to its advanced SmartErgoBase, can be lowered down almost to desk level for a comfortable viewing angle. Low bezel-to-table height is the perfect solution if you use bifocals, trifocals or progressive lens glasses for your computing work. Additionally, it allows for users with greatly different heights to use the monitor in their preferred angle and height settings, helping them reduce fatigue and strain.
  • Built-in stereo speakers
    A pair of high quality stereo speakers built into a display device. It can be visible front firing, or invisible down firing, top firing, rear firing, etc depending on model and design.
  • SmartImage
    SmartImage is an exclusive leading edge Philips technology that analyzes the content displayed on your screen and gives you optimized display performance. This user friendly interface allows you to select various modes like office, photo, movie, game, economy etc., to fit the application in use. Based on the selection, SmartImage dynamically optimizes the contrast, color saturation and sharpness of images and videos for ultimate display performance.
  • SmartPower
    SmartPower is an artificial intelligent technology which dynamically analyzes the content of the screen image to achieve power saving. The backlight intensity can be controlled automatically and pre-set by the system to reduce the power consumption by up to 50%, which saves substantially on energy costs
  • TrueVision
    TrueVision is a proprietary Philips technology that uses advanced algorithm for testing and aligning monitor display which gives you the ultimate display performance that is 4 times more stringent than Windows sRGB requirements.
Philips Brilliance B-line 19B4LCB5 - LED monitor - 19"
LED-backlit LCD monitor - 19"
Aspect Ratio
5:4
Native Resolution
1280 x 1024 at 60 Hz
Pixel Pitch
0.294 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Voltage
Textured black
40.4 cm x 22.7 cm x 50.6 cm
4.61 kg
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV GS, BSMI, GOST, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE
Display Type
Diagonal Size
19"
Aspect Ratio
5:4
Native Resolution
Pixel Pitch
0.294 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
Controls & Adjustments
Volume
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, sRGB colour management, HDCP, SmartContrast, SmartImage, TrueVision, SmartPower, Smart Ergo base
Textured black
40.4 cm x 22.7 cm x 50.6 cm - with stand
4.61 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1.5 Watt
VGA , DVI-D (HDCP) , Audio line-in , Headphones
Mechanical
Tilt Angle
-5/+20
Swivel Angle
130
Rotation Angle
90
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
MTBF
30,000 hour(s)
Power Supply
Internal
Input Voltage
Power Consumption (Typical)
14 Watt
Power Consumption Stand by
0.1 Watt
Included Software
Philips SmartControl Premium
Apple MacOS X, Microsoft Windows 7, Microsoft Windows Vista, Windows 8
Dimensions & Weight Details
With stand - width: 40.4 cm - depth: 22.7 cm - height: 50.6 cm - weight: 4.61 kg , Without stand - width: 40.4 cm - depth: 6.1 cm - height: 34.6 cm - weight: 2.71 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
20 - 80%
98X6 C2G 2m HDMI to DVI-D Digital Video Cable In Stock £11.38
