Product
Philips 17" LCD Monitor LED Backlight 1280 x 1024 5:4 Black Bezel
Clearance!
Clearance
Quicklinx: 98XDWS00 Mfr#: 17S4LSB/00
The Philips LED backlit monitor using recycled materials and PVC BFR-free housing is ideal for eco-friendly productivity.
White LED's are solid state devices which light up to full, consistent brightness faster saving startup time. LED's are free from mercury content, which allows for eco-friendly recycling and disposal process. LED's allow for better dimming control of the LCD backlight, resulting in a super high contrast ratio. It also gives superior color reproduction thanks to consistent brightness across the screen.
  • SmartContrast gives enhanced rich black details
    SmartContrast is a Philips technology that analyses the contents you are displaying, automatically adjusting colours and controlling backlight intensity to dynamically enhance contrast for the best digital images and videos or when playing games where dark hues are displayed. When Economy mode is selected, contrast is adjusted and backlighting fine-tuned for just-right display of everyday office applications and lower power consumption.
  • TrueVision ensures lab quality images
    TrueVision is a proprietary Philips technology that uses an advanced algorithm for testing and aligning monitor display, which gives you the ultimate display performance. Philips ensures that TrueVision monitors leave the factory fine-tuned with this process giving you consistent colour and picture quality.
  • SmartImage pre-sets for easy optimised image settings
    SmartImage is an exclusive leading edge Philips technology that analyses the content displayed on your screen and optimises your display performance. This user-friendly interface allows you to select various modes, like Office, Photo, Movie, Game, Economy etc., to fit the application in use. Based on the selection, SmartImage dynamically optimises the contrast, colour saturation and sharpness of images and videos for ultimate display performance. The Economy mode option offers you major power savings. All in real time at the touch of a single button!
Philips S-line 17S4LSB - LED monitor - 17"
LED-backlit LCD monitor - 17"
Aspect Ratio
5:4
Native Resolution
1280 x 1024 at 60 Hz
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Textured black with black stand
36.7 cm x 19.4 cm x 39.3 cm
3.54 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV GS, BSMI, GOST, SASO, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE, cETLus
3 years warranty
Display Type
Diagonal Size
17"
Aspect Ratio
5:4
Native Resolution
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
Controls & Adjustments
Brightness
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, sRGB colour management, HDCP, SmartContrast, SmartImage, TrueVision, SmartPower
36.7 cm x 19.4 cm x 39.3 cm - with stand
3.54 kg
VGA , DVI-D (HDCP)
Mechanical
Tilt
Tilt Angle
-5/+20
Flat Panel Mount Interface
100 x 100 mm
MTBF
30,000 hour(s)
Power Supply
Internal
11.9 Watt
Power Consumption Stand by
0.2 Watt
Included Software
Philips SmartControl Premium
Apple MacOS X, Microsoft Windows 7, Microsoft Windows Vista, Windows 8
Dimensions & Weight Details
With stand - width: 36.7 cm - depth: 19.4 cm - height: 39.3 cm - weight: 3.54 kg , Without stand - width: 36.7 cm - depth: 6.5 cm - height: 31.9 cm - weight: 3.14 kg
ENERGY STAR Certified
Limited warranty - 3 years
20 - 80%
98XD C2G 1m DVI-D™ M/M Dual Link Digital Video Cable In Stock £7.95
98XD C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £9.31
98XD C2G 5m DVI-D™ M/M Dual Link Digital Video Cable In Stock £16.89
98XD C2G 2M DVI D M/F DIGITAL VIDEO EXT CBL In Stock £10.82
98XD C2G Velocity™ DVI-D™ Male to HDMI® Female Inline Adapter In Stock £5.00
98XD C2G Velocity™ DVI-D™ Female to HDMI® Male Inline Adapter In Stock £7.59
98XD C2G USB to DVI Adapter Up To 2048 x 1152 In Stock £38.98
98XD C2G 2m HDMI to DVI-D Digital Video Cable In Stock £8.65
