Increase your mounts' compatibility with the ACC-DSVW8X4 by Peerless-AV. This low cost adapter rail solution for displays with VESA 800 x 400 mm mounting patterns allows the display to be mounted with the video wall mounts. In addition, keeping the adapter rails located near the corners of the display allows the mount to independently fine tune each corner for precision alignment, giving your video wall a seamless appearance.
- Peerless-AV ACC-DSVW8X4 mounting component - for LCD display - black powder coat
- Product Type
- Mounting component
- Mounting Components
- Bracket adapter
- 9.9 cm x 1.3 cm x 43.2 cm
- 1 kg
- Recommended Use
- LCD display
- VESA Mounting Interface
- 800 x 400 mm
- Max Load Weight
- 57 kg
- Black powder coat
- 5-year warranty
- 9.9 cm
- 1.3 cm
- 43.2 cm
- 1 kg
- Black powder coat
AV Furniture
- Bracket adapter
- Recommended Use
- LCD display
- 800 x 400 mm
- Max Load Weight
- 57 kg
- Limited warranty - 5 years
