Peerless-AV Universal Tilt Wall Mount for 39" to 80" Displays
Quicklinx: 7FTMWS00 Mfr#: PT660/BK
Type: Mounting kit
16 in stock
£62.94 ex VAT
£75.52 inc VAT
Ideally suited for extra large LCD and Plasma screens, the Paramount PT660 tilting mount allows you to mount your LCD/Plasma screen quickly and easily and tilt it forward/back for an improved viewing angle.
Peerless PARAMOUNT Universal Tilt Wall Mount PT660 - mounting kit
Mounting kit
Mounting Components
Wall plate, tilt bracket
Adjustments
Tilt
4.4 kg
Recommended Use
LCD / plasma panel
Recommended Display Size
39"-90"
Max Mounting Pattern Size
832 x 405 mm
Max Load Weight
90.8 kg
Material
Cold-rolled steel
Gloss black
5-year warranty
78.1 cm
6.3 cm
47 cm
4.4 kg
Material
Cold-rolled steel
Gloss black
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD / plasma panel
832 x 405 mm
39"-90"
Adjustments
Tilt
Max Load Weight
90.8 kg
Sorted-For-You, scratch-resistant
Limited warranty - 5 years
Type: Mounting kit
Brand: Peerless-AV
Price Range Ex VAT: 50 - 100
