Peerless-AV Universal Pivot Wall Mount for 10" to 29" Displays
Quicklinx: 7MVVWS00 Mfr#: PP730
Ideally suited for small LCD screens, the Paramount PP730 pivoting wall mount gives you a wide range of screen adjustment to obtain a better viewing angle. The PP730 allows you to tilt your screen forward or back, pan left or right and even extend your flat panel screen away from the wall.
Peerless PARAMOUNT Pivot Wall Mount PP730 mounting kit - Tilt & Swivel - for LCD TV - high-gloss black
Mounting kit (Tilt & Swivel)
Mounting Components
Wall arm, mounting adapter
13.9 cm
Adjustable Width
11.6-20.7 cm
Adjustable Depth
4.7-17.7 cm
0.61 kg
Recommended Use
LCD TV
Recommended Display Size
10"-29"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
11.3 kg
Material
Steel, anodised aluminium
High-gloss black
5-year warranty
13.9 cm
Adjustable Width
11.6-20.7 cm
Adjustable Depth
4.7-17.7 cm
0.61 kg
Material
High-gloss black
AV Furniture
Mounting kit
Mounting Components
Design
Tilt & Swivel
Recommended Use
LCD TV
10"-29"
Max Load Weight
11.3 kg
Scratch-resistant
Limited warranty - 5 years
