Product
Peerless-AV Universal 2x2 Video Wall Mounting Kit for 46-60" Displays
Quicklinx: 9Z0HWS00 Mfr#: DS-VW660-2x2
Creating a 2 x 2 video wall is simple and cost effective with the Peerless-AV DS-VW660-2X2 video wall kit. The single wall frame design is quickly installed and then you're ready to start hanging displays. Built in horizontal adjustment makes aligning displays easy. Due to the thin design, ADA compliance is a non issue with displays measuring 1.71" deep or less.
Peerless Universal 2x2 Video Wall Mounting Kit DS-VW660-2X2 - wall mount
Wall mount
215.3 cm x 5.8 cm x 135.5 cm
27 kg
Recommended Use
4 LCD displays
Recommended Display Size
47"-60"
Max Load Weight
272 kg
Material
Steel
Black powder coat
5 years warranty
215.3 cm
5.8 cm
135.5 cm
27 kg
Material
Steel
Black powder coat
AV Furniture
Wall mount
Mounting Components
Wall plate, wall mount, mounting rails
Recommended Use
4 LCD displays
47"-60"
Max Load Weight
272 kg
Scratch-resistant, security screws
Limited warranty - 5 years
