Ultra Slim is the world's thinnest flat to wall mounting solution at less that 0.84cm - yes that's only 8.4mm! - making it almost invisible once installed. Designed for the next generation of super slim LCD panels this product is a step ahead of anything else available in the market. Own the most discrete wall mount ever developed with the Ultra Slim range from Peerless.
Robust design
Crafted from cold-rolled steel, this mounting kit offers a durable solution for securing flat panels, ensuring longevity and reliability. -
Versatile compatibility
Designed to accommodate flat panels ranging from 40"-80", this ultra-thin flat wall mount provides a perfect fit for a wide array of display sizes, making it an ideal choice for various settings. -
Sleek aesthetics
The scratch-resistant feature of the Peerless Slimline Universal Ultra-Thin Flat Wall Mount ensures that it maintains its sleek, professional appearance, blending seamlessly with any decor.
- Peerless Slimline Universal Ultra-Thin Flat Wall Mount SUF660P mounting kit - for flat panel - high-gloss black
- Product Type
- Mounting kit
- Mounting Components
- Wall plate, bracket adapter
- 90 cm x 1 cm x 55.1 cm
- 2.6 kg
- Recommended Use
- Flat panel
- Recommended Display Size
- 40"-80"
- Max Mounting Pattern Size
- 825 x 449 mm
- Max Load Weight
- 68 kg
- Material
- Cold-rolled steel
- High-gloss black
- 5-year warranty
- 90 cm
- 1 cm
- 55.1 cm
- 2.6 kg
- Material
- Cold-rolled steel
- High-gloss black
AV Furniture
- Mounting kit
- Recommended Use
- Flat panel
- 825 x 449 mm
- 40"-80"
- Max Load Weight
- 68 kg
- Sorted-For-You, scratch-resistant
- Limited warranty - 5 years
