Peerless-AV TruVue Tilting Wall Mount for 32-50" Displays
Quicklinx: 97MRWS00 Mfr#: TRT640
Easily install mid-sized LCD screens with this simple, intuitive mounting solution. The simple hook-on installation combined with its toolless tilt angle adjustment enables flat panel screens to be installed and adjusted quickly. Cables and cords are easily managed behind the screen with large access ports in the wall plate.
Peerless Tru Vue TRT640 mounting kit - for flat panel - black powder coat
Mounting kit - wall-mountable
Mounting Components
Tilt wall mount
49 cm x 7.8 cm x 42.8 cm
Recommended Use
Flat panel
Recommended Display Size
32"-50"
Max Mounting Pattern Size
400 x 400 mm
Max Load Weight
40 kg
Black powder coat
5-year warranty
49 cm
7.8 cm
42.8 cm
Black powder coat
AV Furniture
Mounting kit
Mounting Components
Tilt wall mount
Recommended Use
Flat panel
Placing / Mounting
Wall-mountable
400 x 400 mm
32"-50"
Max Load Weight
40 kg
Integrated spirit level
Limited warranty - 5 years
