Your basket is empty
Peerless-AV TruVue Tilting Wall Mount for 15-37" Displays
Quicklinx: 97MQWS00 Mfr#: TRT632
£15.83 ex VAT
£18.99 inc VAT
This sleek, compact tilting wall mount delivers a big impact for mid-sized screens. Its simple hook-on installation combined with its adjustable tilt allows LCD screens to be installed and adjusted quickly. The tilt angle can be adjusted without the use of tools to give an enhanced viewing position.
Peerless Tru Vue TRT632 - wall mount
Wall mount
22.6 cm x 4 cm x 22 cm
Recommended Use
LCD / plasma panel
Recommended Display Size
15"-37"
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm, 200 x 200 mm, 200 x 100 mm
Max Load Weight
25 kg
Black powder coat
5 years warranty
22.6 cm
4 cm
22 cm
Black powder coat
AV Furniture
Wall mount
Mounting Components
Tilt wall mount
Recommended Use
LCD / plasma panel
15"-37"
Max Load Weight
25 kg
Integrated spirit level
Limited warranty - 5 years
Brand: Peerless-AV
Price Range Ex VAT: 0 - 50
