Your basket is empty
Peerless-AV TruVue Flat-to-Wall Mount for 32-56" LCD & Plasma Displays
Quicklinx: 97MKWS00 Mfr#: TRF650
The TruVue™ series wall mounts combine ease of installation with viewing flexibility. With TRF650, a low-profile design positions the TV just 30mm (1.18") from the wall. The Hook-and-Hang™ system offers easy, one-person installation of the TV. The adaptors hook onto the wall plate for a quick, simple and secure installation.
  • Low profile design positions the TV just 30mm (1.18") from the wall.
  • Universal mount fits TVs with mounting patterns up to VESA 700x400mm.
  • Simple Hook-and-Hang™ design for quick and easy installation.
  • Mounts to wood studs, concrete, cinder block or metal studs (metal stud accessory required).
  • Installation hardware included.
  • Tested to four times stated load capacity.
Peerless Tru Vue TRF650 - wall mount
Wall mount
72.6 cm x 3 cm x 43 cm
Recommended Use
LCD / plasma panel
Recommended Display Size
32"-56"
Max Mounting Pattern Size
700 x 400 mm
Max Load Weight
70 kg
Black powder coat
5 years warranty
72.6 cm
3 cm
43 cm
Black powder coat
AV Furniture
Wall mount
Mounting Components
Wall mount
Recommended Use
LCD / plasma panel
700 x 400 mm
32"-56"
Max Load Weight
70 kg
Integrated spirit level
Limited warranty - 5 years
