Your basket is empty
Peerless-AV TruVue Flat-to-Wall-Mount for 15-37" Displays
Quicklinx: 97MHWS00 Mfr#: TRF632
19 in stock
£11.40 ex VAT
£13.68 inc VAT
Standard delivery Delivered within 3-5 working days
Locate mid-sized screens almost anywhere with this compact, versatile mount. Simply attach the wall plate to the wall, the adapter to the screen and hook it on to the wall plate - done. At only 14 mm (0.55") from the wall, this sleek mount is ideal for low-profile applications.
Peerless Tru Vue TRF632 - wall mount
Wall mount
Recommended Use
LCD display
Recommended Display Size
15"-37"
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm, 200 x 200 mm, 200 x 100 mm
Max Load Weight
25 kg
Black powder coat
5 years warranty
Black powder coat
AV Furniture
Wall mount
Mounting Components
Wall mount
Recommended Use
LCD display
15"-37"
Max Load Weight
25 kg
Integrated spirit level
Limited warranty - 5 years
Brand: Peerless-AV
Price Range Ex VAT: 0 - 50
