The TruVue™ series wall mounts combine ease of installation with viewing flexibility. With TRF630, a low-profi le design positions the TV just 0.56" (14mm) from the wall. The Hook-and-Hang™ system off ers easy, one-person installation of the TV. Locate small screens almost anywhere with this compact, versatile mount. Simply attach the wall plate to the wall, the adapter to the screen and hook it on to the wall plate - done. At only 14 mm (0.55") from the wall, this sleek mount is ideal for low-profile applications.
- Positions TV only 0.56" (14mm) from the wall.
- Low-profi le design creates a clean, concealed look.
- Includes necessary wall and TV attachment hardware.
- Accommodates VESA 75 and 100mm TV mounting hole patterns.
- Mounts to wood stud, concrete, cinder or breeze block surface.
- TV adaptor plate simply slides into the wall plate for a quick and easy installation.
- Design is UL listed and tested to four times stated load capacity.
- Peerless Tru Vue TRF630 mounting kit - for LCD display - black powder coat
- Product Type
- Mounting kit - wall-mountable
- Mounting Components
- Wall mount
- 12 cm x 1.4 cm x 12.4 cm
- Recommended Use
- LCD display
- Recommended Display Size
- 10"-29"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Max Load Weight
- 20 kg
- Black powder coat
- 5-year warranty
- 12 cm
- 1.4 cm
- 12.4 cm
- Black powder coat
AV Furniture
- Mounting kit
- Wall mount
- Recommended Use
- LCD display
- Placing / Mounting
- Wall-mountable
- 10"-29"
- Max Load Weight
- 20 kg
- Integrated spirit level
- Limited warranty - 5 years
