Smoothly pull out and position this mount to the ideal viewing angle then retract it tight to the wall to save space. Level the screen at any time, even after installation. With integrated cable management, cords and cables are never in the way - even when extending and retracting the display.
- Peerless Tru Vue TRP732 mounting kit - for LCD display - black powder coat
- Product Type
- Mounting kit - wall-mountable
- Mounting Components
- Pivot wall mount
- 29.9 cm
- Adjustable Depth
- 9.8-25.8 cm
- Adjustments
- Tilt
- Recommended Use
- LCD display
- Recommended Display Size
- 22"-40"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm, 200 x 200 mm, 200 x 100 mm
- Max Load Weight
- 15 kg
- Black powder coat
- 5-year warranty
- 29.9 cm
- Adjustable Depth
- 9.8-25.8 cm
- Black powder coat
AV Furniture
- Mounting kit
- Pivot wall mount
- Recommended Use
- LCD display
- Placing / Mounting
- Wall-mountable
- 22"-40"
- Adjustments
- Tilt
- Max Load Weight
- 15 kg
- Swivel adjustment, integrated spirit level
- Limited warranty - 5 years
