Your basket is empty
Peerless-AV TruVue Black Pivot Wall Mount for 15-32" Displays
Quicklinx: 97MMWS00 Mfr#: TRP732
£24.40 ex VAT
£29.28 inc VAT
Smoothly pull out and position this mount to the ideal viewing angle then retract it tight to the wall to save space. Level the screen at any time, even after installation. With integrated cable management, cords and cables are never in the way - even when extending and retracting the display.
Peerless Tru Vue TRP732 - wall mount
Wall mount
29.9 cm
Adjustable Depth
9.8-25.8 cm
Tilt
Recommended Use
LCD display
Recommended Display Size
15"-32"
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm, 200 x 200 mm, 200 x 100 mm
Max Load Weight
15 kg
Black powder coat
5 years warranty
29.9 cm
Adjustable Depth
9.8-25.8 cm
Black powder coat
AV Furniture
Wall mount
Mounting Components
Pivot wall mount
Recommended Use
LCD display
15"-32"
Tilt
Max Load Weight
15 kg
Swivel adjustment, integrated spirit level
Limited warranty - 5 years
Brand: Peerless-AV
Price Range Ex VAT: 0 - 50
