Product
Peerless-AV Triple Monitor Desktop Arm Mount for up to 24"
Quicklinx: BR91WS00 Mfr#: LCT620AT-G
The LCT620AT-G Desktop Monitor Mount features three attractive height adjustable articulating arms that provide perfect ergonomics with optimum monitor positioning for virtually all users. The grommet mounting base provides limitless mounting options on any desktop or countertop surface between ½" to 2" (12 to 55mm) thick.
Peerless-AV LCT620AT-G - mounting kit
Mounting kit
Mounting Components
3 articulating arms, desk grommet
Adjustments
Roll, tilt
13.3 kg
Recommended Use
3 LCD displays
Recommended Display Size
10"-24"
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
8.1 kg
Material
Aluminium
5 years warranty
13.3 kg
Material
Aluminium
AV Furniture
Mounting kit
Mounting Components
Recommended Use
3 LCD displays
Cable Management
Integrated cable management
10"-24"
Adjustments
Roll, tilt
Max Load Weight
8.1 kg
Min Load Weight
3.8 kg
TAA Compliant
Adjustable height, pivot
Limited warranty - 5 years
