Product
Peerless-AV Stand with Tinted Glass Shelf for 32-65" Flat Panel Displays
Quicklinx: 9Z3VWS00 Mfr#: SS560G
The Flat Panel Stand is designed to provide ideal display viewing position, centralize audio video components and match the decor of any environment. The full line of accessories enables each stand to be fully tailored to meet specific requirements; whether video conferencing from a boardroom or presenting on a trade show floor. And the internal cable management hides all the AV cabling, providing a clean, clutter-free look.
Peerless SS560G Flat Panel Cart - stand
Stand
86.4 cm x 69.7 cm x 152 cm
Adjustments
Tilt
32.6 kg
Recommended Use
LCD / plasma panel / AV System
Recommended Display Size
Up to 65"
Max Load Weight
90.7 kg
Black powder coat
86.4 cm
69.7 cm
152 cm
32.6 kg
Black powder coat
AV Furniture
Stand
Recommended Use
Shelf Qty
1
Cable Management
Integrated cable management
Up to 65"
Adjustments
Tilt
Max Load Weight
90.7 kg
Adjustable height, adjustable foot, glass shelf
