Peerless-AV SmartMount Universal Tilt Wall Mount for 46" to 90" Displays
Quicklinx: 7MVDWS00 Mfr#: ST670P
Type: Mounting kit
14 In Stock
£125.74 ex VAT
£150.88 inc VAT
Ideally suited for XX large LCD and plasma screens, the SmartMount ST670P tilting wall mount allows you to mount your LCD/plasma screen quickly and easily and tilt it forward/back for an improved viewing angle.
Peerless SmartMount Universal Tilt Wall Mount ST670P mounting kit - for flat panel - black
Mounting kit
Mounting Components
Wall plate, tilt bracket
95.9 cm x 7.9 cm x 52.4 cm
5.7 kg
Recommended Use
Flat panel
Recommended Display Size
49"-90"
VESA Mounting Interface
Up to 895 x 450 mm
Max Load Weight
113.4 kg
5-year warranty
95.9 cm
7.9 cm
52.4 cm
5.7 kg
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Flat panel
Up to 895 x 450 mm
49"-90"
Max Load Weight
113.4 kg
Adjustable width, Sorted-For-You, scratch-resistant, Incre-Lok
Limited warranty - 5 years
Type: Mounting kit
Brand: Peerless-AV
