Your basket is empty
Peerless-AV SmartMount Universal Flat Wall Mount for 60" to 95" Displays
Quicklinx: 7MV2WS00 Mfr#: SF680P
Type: Mounting kit
£107.91 ex VAT
£129.49 inc VAT
Ideally suited for XXX large LCD and plasma screens, the SmartMount SF680P flat-to-wall mount allows you to mount even the very largest flat panel screens quickly and easily.
Peerless SmartMount Universal Flat Wall Mount SF680P - mounting kit
Mounting kit
Mounting Components
Wall plate, bracket adapter
116.2 cm x 5 cm x 76.8 cm
6.1 kg
Recommended Use
LCD / plasma panel
Recommended Display Size
60"-95"
Flat Panel Mount Interface
Up to 1111 x 745 mm
Max Load Weight
158.8 kg
Material
Steel, fused epoxy
5 years warranty
116.2 cm
5 cm
76.8 cm
6.1 kg
Material
Steel, fused epoxy
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD / plasma panel
Up to 1111 x 745 mm
60"-95"
Max Load Weight
158.8 kg
Sorted-For-You, scratch-resistant
Limited warranty - 5 years
Type: Mounting kit
Brand: Peerless-AV
Price Range Ex VAT: 100 - 150
