Peerless-AV SmartMount Universal Flat Wall Mount for 46" to 90" Displays
Quicklinx: 7MV1WS00 Mfr#: SF670P
Type: Mounting kit
20 in stock
£84.40 ex VAT
£101.28 inc VAT
Ideally suited for XX large LCD and plasma screens, the SmartMount SF670P flat-to-wall mount allows you to mount your LCD/plasma screen quickly and easily.
Peerless SmartMount Universal Flat Wall Mount SF670P - mounting kit
Mounting kit
Mounting Components
Wall plate, bracket adapter
95.9 cm x 5 cm x 52.4 cm
4.7 kg
Recommended Use
LCD / plasma panel
Recommended Display Size
46"-90"
VESA Mounting Interface
895 x 450 mm
Max Load Weight
113.4 kg
Material
Steel, fused epoxy
5-year warranty
95.9 cm
5 cm
52.4 cm
4.7 kg
Material
Steel, fused epoxy
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD / plasma panel
895 x 450 mm
46"-90"
Max Load Weight
113.4 kg
Sorted-For-You, scratch-resistant
Limited warranty - 5 years
Type: Mounting kit
Brand: Peerless-AV
Price Range Ex VAT: 50 - 100
