Ideally suited for extra large LCD and plasma screens, the SmartMount SF660P flat-to-wall mount allows you to mount your LCD/plasma screen quickly and easily.
- Peerless SmartMount Universal Flat Wall Mount SF660P - mounting kit
- Product Type
- Mounting kit - wall-mountable
- Mounting Components
- Wall plate, bracket
- 86.7 cm x 2.8 cm x 45.7 cm
- 4.2 kg
- Recommended Use
- Flat panel
- Recommended Display Size
- 39"-80"
- VESA Mounting Interface
- Up to 824 x 405 mm
- Max Load Weight
- 90.7 kg
- Black
- 5-year warranty
- 86.7 cm
- 2.8 cm
- 45.7 cm
- 4.2 kg
- Black
AV Furniture
- Mounting kit
- Recommended Use
- Flat panel
- Placing / Mounting
- Wall-mountable
- 39"-80"
- Max Load Weight
- 90.7 kg
- Limited warranty - 5 years
