Product
Brand
Peerless-AV SmartMount Universal Flat Wall Mount for 22" to 40" Displays
Clearance!
Clearance
Last Few Remaining
Limited Time Offer
Quicklinx: 7G5BWS00 Mfr#: SF632P
Peerless SF632P universal flat wall mount for LCDs 22-40-inch. The ultra-slim wall plate keeps the screen close to the wall for a very discreet installation that is perfect for digital signage, POS stations, or office applications.
For a quick and easy installation it may be mounted to a single wood stud, concrete or cinder block. Mounts to metal stud using accessory metal stud fasteners. Compatible with VESA 75mm, 100mm, 200mm x 100mm, and 200mm x 200mm mounting hole patterns.
