Product
Peerless-AV SmartMount Projector Mount - Up to 24.9kg
Quicklinx: C7KVWS00 Mfr#: PJF3-EXA(-W)
Peerless-AV’s PJF3 Projector Mount is loaded with an array of features to enhance your viewing experience. Using a sleek column design, the PJF3 allows versatile mounting of the projector. Its toolless height, image adjustment and quick-release mechanism provide easy setup and projector maintenance.
Peerless-AV SmartMount Projector Mount PJF3-EXA-W - mounting kit (Tilt & Swivel)
Mounting kit (Tilt & Swivel)
Mounting Components
Extension column, ceiling plate, mounting adapter
44.8 cm x 44.8 cm
Adjustable Height
33-45.7 cm
Tilt
-20° to 20°
Rotation
360°
Adjustments
Roll, height
1.82 kg
Recommended Use
Projector
Max Mounting Pattern Size
448 x 448 mm
Max Load Weight
24.9 kg
White powder coat
5 years warranty
44.8 cm
44.8 cm
Adjustable Height
33-45.7 cm
1.82 kg
White powder coat
AV Furniture
Mounting kit
Mounting Components
Design
Tilt & Swivel
Recommended Use
Projector
448 x 448 mm
Cable Management
Integrated cable management
Tilt
-20° to 20°
Rotation
360°
Adjustments
Roll, height
Max Load Weight
24.9 kg
Limited warranty - 5 years
