The Floor TV Stand or Cart is one of the sharpest looking, most robust and functional stands ever, perfect for exhibitions, conferences or any other public venue. Under the TV mount there is plenty of space to conceal content drivers and surge protectors. Its internal cable management system conceals cables and cords, delivering a clean look for any application.
- Peerless SS560FK - stand - for touch screen - black powder coat
- Product Type
- Stand - floor-standing, floor stand mountable
- 85.1 cm x 67.3 cm x 115.5 cm
- Tilt
- 0° to 30°
- 47.4 kg
- Recommended Use
- Touch screen
- Recommended Display Size
- 32"-75"
- Max Mounting Pattern Size
- 729 x 433 mm
- Max Load Weight
- 68 kg
- Material
- Cold-rolled steel
- Black powder coat
- 85.1 cm
- 67.3 cm
- 115.5 cm
- 47.4 kg
- Material
- Cold-rolled steel
- Black powder coat
AV Furniture
- Stand
- Recommended Use
- Touch screen
- Placing / Mounting
- Floor-standing, floor stand mountable
- 729 x 433 mm
- Cable Management
- Integrated cable management
- 32"-75"
- Tilt
- 0° to 30°
- Max Load Weight
- 68 kg
