Peerless-AV Security Adaptor Plate For 23"-37" Flat Panel Displays - Landscape Only
Quicklinx: 9YZHWS00 Mfr#: PLP-UNM
£74.75 ex VAT
£89.70 inc VAT
Marketing description is not available.
Peerless Universal I-Shaped Adaptor PLP-UNM mounting component - for flat panel - black
Mounting component
Mounting Components
Mounting adapter
41.9 cm x 1.8 cm x 42.5 cm
1.95 kg
Recommended Use
Flat panel
Recommended Display Size
22"-50"
VESA Mounting Interface
100 x 100 mm, 200 x 200 mm, 400 x 300 mm, 400 x 100 mm, 400 x 200 mm, 400 x 400 mm
Max Load Weight
68.2 kg
Material
Cold-rolled steel
5-year warranty
41.9 cm
1.8 cm
42.5 cm
1.95 kg
Material
Cold-rolled steel
AV Furniture
Mounting component
Mounting Components
Mounting adapter
Recommended Use
Flat panel
22"-50"
Max Load Weight
68.2 kg
Finish
Powder coated
Limited warranty - 5 years
Brand: Peerless-AV
