Peerless-AV’s Rotational Wall Mount has been designed to support the features and functionality of the 55" Samsung Flip display. The mount’s rotational interface allows the user to easily rotate the display 90° from landscape to portrait, and holds the display at a negative 4.5° to further promote ergonomics with a more natural angled writing surface. The unique cable management system allows cables to be routed through the interface, which keeps the cabling safe and abrasion free when rotating the display. With a robust feature set featured on safety and durability, the Rotational Wall Mount is ideal for collaboration spaces in corporate or education settings.
- Peerless Rotational Mount Interface RMI3-FLIP bracket - for LCD display / touchscreen - gloss white
- Product Type
- Bracket - wall-mountable
- 55.1 cm x 8.7 cm x 47 cm
- Tilt
- -4.5°
- Recommended Use
- LCD display / touchscreen
- Recommended Display Size
- 55"
- VESA Mounting Interface
- 400 x 400 mm
- Max Load Weight
- 31.8 kg
- Gloss white
- Designed For
- Samsung Flip WM55H
- 55.1 cm
- 8.7 cm
- 47 cm
- Gloss white
AV Furniture
- Bracket
- Recommended Use
- Placing / Mounting
- Wall-mountable
- 400 x 400 mm
- 55"
- Tilt
- -4.5°
- Max Load Weight
- 31.8 kg
- Finish
- Powder coated
- Details
- Portrait orientation, landscape orientation
Dimensions & Weight Details
- Shipping Dimensions (WxDxH) / Weight
- 51.44 cm x 12.07 cm x 66.37 cm / 11.5 kg
- Designed For
