Go from landscape to portrait with a simple pull of the spring-loaded lever, eliminating the need to remove the screen from the mount whenever the content orientation changes. In addition, the RMI1 enables a mounted screen to be easily rotated and set at 15-degree increments within 360 degrees. Ideal for standard or creative digital signage displays - landscape, portrait, waves, zigzag and 45-degree angle patterns - the possibilities are endless. The RMI1 is compatible with Peerless' selection of wall mounts, ceiling mounts, carts and stands.
- Peerless Rotational Mount Interface RMI1 - mounting component - for LCD display - black
- Product Type
- Mounting component - ceiling mountable, wall-mountable
- Mounting Components
- Mount
- 32.9 cm x 2.4 cm x 18.8 cm
- 2.3 kg
- Recommended Use
- LCD display
- Recommended Display Size
- 22" - 71"
- Max Load Weight
- 79.5 kg
- Material
- Fused epoxy
- Black
- 5-year warranty
- 32.9 cm
- 2.4 cm
- 18.8 cm
- 2.3 kg
- Material
- Fused epoxy
- Black
AV Furniture
- Mount
- Recommended Use
- LCD display
- Placing / Mounting
- Ceiling mountable, wall-mountable
- 22" - 71"
- Max Load Weight
- 79.5 kg
- Rotating, tamper resistant adjustment screws, portrait to landscape movement, scratch-resistant, lockable
- Limited warranty - 5 years
