The LCT620AQ-G Desktop Monitor Mount features four attractive height adjustable articulating arms that provide perfect ergonomics with optimum monitor positioning for virtually all users. The grommet mounting base provides limitless mounting options on any desktop or countertop surface between ½" to 2" (12 to 55mm) thick.
- Peerless-AV LCT620AQ-G - mounting kit
- Product Type
- Mounting kit
- Mounting Components
- 4 articulating arms, desk grommet
- Adjustments
- Roll, tilt
- 17.3 kg
- Recommended Use
- 4 LCD displays
- Recommended Display Size
- Up to 24"
- Flat Panel Mount Interface
- 100 x 100 mm, 75 x 75 mm
- Max Load Weight
- 8.1 kg
- Material
- Aluminium
- 5 years warranty
- 17.3 kg
- Material
- Aluminium
AV Furniture
- Mounting kit
- Recommended Use
- 4 LCD displays
- Cable Management
- Integrated cable management
- Up to 24"
- Adjustments
- Roll, tilt
- Max Load Weight
- 8.1 kg
- Min Load Weight
- 3.8 kg
- TAA Compliant
- Adjustable height, pivot
- Limited warranty - 5 years
