The PRSS projector mount allows for independent pitch, roll and swivel alignment with two easily accessible adjustment points. Just set the mount to the desired position and secure it in place. It will hold its position even during projector maintenance. With its discreet, low-profile design the projector mount is perfect for flush mounting applications. With Peerless-AV PRSS projector mount, just set it and forget it.
Effortless projector maintenance
With its intuitively designed quick-release thumbscrew that smoothly unwinds to enable easy-glide removal of the projector in and out of the mount. No tools required.
- Peerless PRSS PRSS-UNV-W mounting kit - for projector - white powder coat
- Product Type
- Mounting kit - ceiling mountable
- Mounting Components
- Ceiling mount
- Adjustable Width
- 12.2- 44.8 cm
- Adjustable Depth
- 12.2- 44.8 cm
- Adjustable Height
- 9.2 -11.8 cm
- Adjustments
- Roll, yaw, tilt
- 2.14 kg
- Recommended Use
- Projector
- Max Load Weight
- 22 kg
- White powder coat
- Image Colour Disclaimer
- The displayed product image may be a different colour
- Adjustable Width
- 12.2- 44.8 cm
- Adjustable Depth
- 12.2- 44.8 cm
- Adjustable Height
- 9.2 -11.8 cm
- 2.14 kg
- White powder coat
AV Furniture
- Mounting kit
- Ceiling mount
- Recommended Use
- Projector
- Placing / Mounting
- Ceiling mountable
- Adjustments
- Roll, yaw, tilt
- Max Load Weight
- 22 kg
- Quick release
