Peerless-AV PRSS Projector Mount for Projectors up to 22kg
Quicklinx: 9YXMWS00 Mfr#: PRSS-UNV
The PRSS projector mount offers one of the fastest and easiest installations available in the market. It allows for independent pitch, roll and swivel alignment with two easily accessible adjustment points. Just set the mount to the desired position and secure it in place. It will hold its position even during projector maintenance. With its discreet, low-profile design the projector mount is perfect for flush mounting applications.
  • Effortless projector maintenance
    With its intuitively designed quick-release thumbscrew that smoothly unwinds to enable easy-glide removal of the projector in and out of the mount. No tools required.
Peerless PRSS PRSS-UNV mounting kit - for projector - black powder coat
Mounting kit - ceiling mountable
Mounting Components
Ceiling mount
Adjustable Width
12.2- 44.8 cm
Adjustable Depth
12.2- 44.8 cm
Adjustable Height
9.2 -11.8 cm
Adjustments
Roll, yaw, tilt
2.14 kg
Recommended Use
Projector
Max Load Weight
22 kg
Black powder coat
Adjustable Width
12.2- 44.8 cm
Adjustable Depth
12.2- 44.8 cm
Adjustable Height
9.2 -11.8 cm
2.14 kg
Black powder coat
AV Furniture
Mounting kit
Mounting Components
Ceiling mount
Recommended Use
Projector
Placing / Mounting
Ceiling mountable
Adjustments
Roll, yaw, tilt
Max Load Weight
22 kg
Quick release
