Product
Peerless-AV PLP Flat Panel Adaptor Plate
Quicklinx: 9YZVWS00 Mfr#: PLP-PAN65
Large Flat Panel adapter plates (PLP models) are either universally compatible with most large flat panels, or uniquely compatible with one screen make or model. Peerless adapter plates for flat panels allow users to choose between Peerless' wide array of applications and accessories to mount a flat panel virtually anywhere. Most models feature security fasteners for theft resistance
Peerless PLP PAN65 - mounting component
Mounting component
Mounting Components
Adapter plate
113 cm x 5.9 cm x 42.9 cm
6.9 kg
Recommended Use
Plasma panel
113 cm
5.9 cm
42.9 cm
6.9 kg
AV Furniture
Mounting component
Mounting Components
Adapter plate
Recommended Use
Plasma panel
