Vector Pro II provides a clean look with its cable management capabilities. The included extension column connector incorporates internal cable management paths that keep unsightly cords concealed from view. The mount also features a ceiling plate, ball and socket design, multidirectional positioning (roll, pitch and yaw) for proper image alignment and preinstalled security hardware at every connection point. This projector mount is perfect for use in classrooms, boardrooms, hotels, bars and restaurants or anywhere a projector needs to be mounted. The Vector Pro II can be flush mounted to the ceiling or mounted on the wall. It can also be mounted using 1-1/2" (38 mm) diameter extension column or 1/2" (38 mm) thread rod.
- Peerless-AV Vector Pro II mounting component - for projector - black powder coat
- Product Type
- Mounting component - ceiling mountable, wall-mountable
- Mounting Components
- Mount, extension column connector
- Adjustable Height
- 6.4-14 cm
- Adjustments
- Roll, pitch, yaw
- Recommended Use
- Projector
- Max Load Weight
- 22 kg
- Black powder coat
- 5-year warranty
- Adjustable Height
- 6.4-14 cm
- Black powder coat
AV Furniture
- Recommended Use
- Projector
- Placing / Mounting
- Ceiling mountable, wall-mountable
- Cable Management
- Integrated cable management
- Adjustments
- Roll, pitch, yaw
- Max Load Weight
- 22 kg
- Quick release
- Limited warranty - 5 years
