Peerless-AV PJF2 Projector Mount Without Adaptor up to 23kg- Black
Quicklinx: 9YYXWS00 Mfr#: PJF2-1/BK
£44.16 ex VAT
£52.99 inc VAT
Vector Pro II provides a clean look with its cable management capabilities. The included extension column connector incorporates internal cable management paths that keep unsightly cords concealed from view. The mount also features a ceiling plate, ball and socket design, multidirectional positioning (roll, pitch and yaw) for proper image alignment and preinstalled security hardware at every connection point. This projector mount is perfect for use in classrooms, boardrooms, hotels, bars and restaurants or anywhere a projector needs to be mounted. The Vector Pro II can be flush mounted to the ceiling or mounted on the wall. It can also be mounted using 1-1/2" (38 mm) diameter extension column or 1/2" (38 mm) thread rod.
Peerless-AV Vector Pro II - mounting component
Mounting component - ceiling mountable, wall-mountable
Mounting Components
Mount, extension column connector
Adjustable Height
6.4-14 cm
Adjustments
Roll, pitch, yaw
Recommended Use
Projector
Max Load Weight
22 kg
Black powder coat
5 years warranty
Adjustable Height
6.4-14 cm
Black powder coat
AV Furniture
Mounting component
Mounting Components
Recommended Use
Projector
Placing / Mounting
Ceiling mountable, wall-mountable
Cable Management
Integrated cable management
Adjustments
Roll, pitch, yaw
Max Load Weight
22 kg
Quick release
Limited warranty - 5 years
Brand: Peerless-AV
Price Range Ex VAT: 0 - 50
