Peerless-AV Peerless Projector Ceiling/Wall Mount, 17.2"-25.2" Adj Ext (Black)
Quicklinx: 7MTPWS00 Mfr#: PPB
These versatile, ready to install mount models offer the convenience of installation to the ceiling or the wall and provide drop length options without the need of additional accessories. These mount models provide the first true comprehensive projector mounting solution in a single package.
Peerless PARAMOUNT Ceiling/Wall Projector Mount with Adjustable Extension PPB mounting kit - Tilt & Swivel - for projector - black
Mounting kit (Tilt & Swivel)
Mounting Components
Extension column, ceiling plate, mounting adapter, horizontal adjuster
Adjustable Width
16.5-42 cm
Adjustable Depth
16.5-42 cm
Adjustable Height
42.5-65.2 cm
1.7 kg
Recommended Use
Projector
Max Load Weight
22.6 kg
Material
Cold-rolled steel
5-year warranty
Adjustable Width
16.5-42 cm
Adjustable Depth
16.5-42 cm
Adjustable Height
42.5-65.2 cm
1.7 kg
Material
Cold-rolled steel
AV Furniture
Mounting kit
Mounting Components
Design
Tilt & Swivel
Recommended Use
Projector
Max Load Weight
22.6 kg
Scratch-resistant
Limited warranty - 5 years
