Product
Peerless-AV Paramount Flat Panel Ceiling Mount for 15-37" Displays
Quicklinx: 9Z1PWS00 Mfr#: PC932B/BK
No wall space? No problem. This VESA compliant LCD ceiling mount gets the TV up easily and offers an incredible range of viewing options. Installation is made simple with its one-, two-, three- design. Simply attach the ceiling plate, attach the adapter to the screen and hook-on the TV on to the mount - Done. This LCD TV mount delivers the ultimate in positioning options with its tilt and infinite swivel options for that ultimate flat panel viewing experience.
Peerless PARAMOUNT LCD Ceiling Mount PC932B - mounting kit (Tilt & Swivel)
Mounting kit (Tilt & Swivel)
Mounting Components
Extension column, ceiling plate, tilt bracket, mounting adapter
16.5 cm x 16.5 cm
Adjustable Height
35-55.6 cm
2.3 kg
Recommended Use
LCD TV
Recommended Display Size
15"-37"
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm, 200 x 200 mm, 200 x 100 mm
Material
Cold-rolled steel
5 years warranty
16.5 cm
16.5 cm
Adjustable Height
35-55.6 cm
2.3 kg
Material
Cold-rolled steel
AV Furniture
Mounting kit
Mounting Components
Design
Tilt & Swivel
Recommended Use
LCD TV
15"-37"
Scratch-resistant
Limited warranty - 5 years
