Peerless-AV Paramount Flat Panel Ceiling Mount for 15-24" Displays
Quicklinx: 9Z1LWS00 Mfr#: PC930A/BK
No wall space? No problem. The ceiling is a great place to mount a flat panel when there is no wall available. Ceiling installation is made simple with PC930s one-, two-, three- design. Simply attach the ceiling plate, attach the adapter to the screen and hook-on the TV on to the mount - Done. This VESA compliant LCD mount delivers the ultimate in positioning options with its tilt and infinite swivel to achieve an ideal flat panel viewing experience.
Peerless PARAMOUNT LCD Ceiling Mount PC930A - mounting kit - Tilt & Swivel - for LCD TV - black
Mounting kit (Tilt & Swivel)
Mounting Components
Extension column, ceiling plate, tilt bracket, mounting adapter
16.5 cm x 16.5 cm
Adjustable Height
24.8-35.3 cm
1.47 kg
Recommended Use
LCD TV
Recommended Display Size
15"-24"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Material
Cold-rolled steel
5-year warranty
16.5 cm
16.5 cm
Adjustable Height
24.8-35.3 cm
1.47 kg
Material
Cold-rolled steel
AV Furniture
Mounting kit
Mounting Components
Design
Tilt & Swivel
Recommended Use
LCD TV
15"-24"
Scratch-resistant
Limited warranty - 5 years
