Product
Brand
Peerless-AV OneMount Flat Panel Modular Wall Mount for 23-84" Screens
Quicklinx: 9YZXWS00 Mfr#: ONE-TP
One model. One box. One solution. One mount. The OneMount Flat Panel Modular Wall Mount is one solution to fit all screens from 23" to 84". The mount's inclusive size options, versatile functionality and modular design are ideal for residential or commercial applications. The Modular Mount is comprised of three interlocking wall plates that can be used in one, two or three plate configurations, depending on screen size. This mount offers smooth, continuous one touch tilt of +15º/-5º, allowing for easy adjustment to achieve the perfect viewing angle without tools. Mount assembly is expedited with the center wall plate's built-in screw design, easily adjustable brackets and included mounting and screen attachment hardware. No extra adapters. No special tools. Just OneMount Flat Panel Modular Wall Mount in one compact package.
Peerless OneMount Flat Panel Modular Wall Mount ONE-TP - mounting kit
Mounting kit
Mounting Components
Tilt bracket, fasteners, 3-piece wall plate
8.1 cm
Adjustable Width
48.9-107.4 cm
Adjustable Height
34.9-69.3 cm
6.8 kg
Recommended Use
Flat panel
Recommended Display Size
23" - 84"
Max Load Weight
113.4 kg
Material
Cold-rolled steel, fused epoxy
5 years warranty
8.1 cm
Adjustable Width
48.9-107.4 cm
Adjustable Height
34.9-69.3 cm
6.8 kg
Material
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Flat panel
23" - 84"
Adjustments
Tilt
Max Load Weight
113.4 kg
Scratch-resistant, Incre-Lok
Limited warranty - 5 years
