Peerless-AV’s Mobile Cart with Rotational Interface has been designed to support the features and functionality of the 55" Samsung Flip display. Mobility, appealing design, display height adjustment and a pre-assembled base ensure quick assembly, while providing a rigid, but attractive structure to match the display. The 4" casters make it easy to move from room-to-room and optional bumper accessories ensure nothing is damaged along the way. The mount’s rotational interface allows the user to easily rotate the display 90° from landscape to portrait, and holds the display at a negative 4.5° to further promote ergonomics with a more natural angled writing surface. The unique cable management system allows cables to be routed through the interface, which keeps the cabling safe and abrasion free when rotating the display. With a robust feature set featured on safety and durability, the Mobile Cart with Rotational Interface is ideal for collaboration spaces in corporate or education settings.
- Peerless-AV SR560-FLIP - cart - for flat panel - gloss white
- Product Type
- Cart
- 88.9 cm x 163.2 cm x 73.7 cm
- Tilt
- -4.5°
- Rotation
- 90°
- Adjustments
- Height, rotation
- Recommended Use
- Flat panel
- Recommended Display Size
- 55"
- VESA Mounting Interface
- 400 x 400 mm
- Max Load Weight
- 31.8 kg
- Gloss white
- Wheels Qty
- 4
- Designed For
- Samsung Flip WM55H
- 88.9 cm
- 163.2 cm
- 73.7 cm
- Gloss white
AV Furniture
- Cart
- Recommended Use
- Flat panel
- 400 x 400 mm
- Cable Management
- Integrated cable management
- 55"
- Tilt
- -4.5°
- Rotation
- 90°
- Adjustments
- Height, rotation
- Max Load Weight
- 31.8 kg
- Wheels Qty
- 4
- Wheel Diameter
- 10.2 cm
- Finish
- Powder coated
- Details
- Portrait orientation, landscape orientation
Dimensions & Weight Details
- Shipping Dimensions (WxDxH) / Weight
- 101.6 cm x 21.59 cm x 121.92 cm / 37.1 kg
- Designed For
