Your basket is empty
Peerless-AV Media Player Holder Accessory for SP850 & SA Arms
Quicklinx: 9Z02WS00 Mfr#: DSX750
£107.91 ex VAT
£129.49 inc VAT
Quickly, securely and inconspicuously house a media player control device behind a wall mounted display with Peerless' DSX750 Media Player Storage Accessory. Compatible with a number of Peerless swivel and articulating wall mounts, or can be used as a stand-alone flat wall mount, this media equipment enclosure eliminates the problems associated with securing the media device with tape or straps behind the display or installing it remotely in a wiring closet. It also offers built-in cable management, security and prop-open service access features critical for easy maintenance of digital signage applications. A special arm within the DSX750 enables the unit to prop open for easy servicing of the media player or display without taking down the screen or disassembling the mount. This accessory box fits snugly between the display and the mounting plate, enabling the media player and display to be tightly coupled for a neat appearance as well as one-stop installation and access.
Peerless DSX750 Media Player Holder Accessory - mounting kit
Mounting kit - wall-mountable, behind flat-panel
6 kg
Recommended Use
LCD / plasma panel / digital player
Recommended Display Size
32" - 60"
Flat Panel Mount Interface
100 x 100 mm, 200 x 200 mm, 200 x 100 mm
6 kg
AV Furniture
Mounting kit
Recommended Use
Placing / Mounting
Wall-mountable, behind flat-panel
Cable Management
Cable Management System (CMS)
32" - 60"
Scratch-resistant, security screws, prop-open mechanism
Brand: Peerless-AV
Price Range Ex VAT: 100 - 150
