Product
Peerless-AV LCD/Plasma Trolley with Metal Shelf 32" - 75" max
Clearance!
Clearance
Last Few Remaining
Limited Time Offer
Quicklinx: 91VQWS00 Mfr#: SR560M
Sorry but this product has been discontinued.
View used stock
The SR560M Flat Panel TV Cart has been redesigned to include all of the features you may need, making it perfect for any application. Mobility, appealing design, display height adjustment, pre-assembled base and UL certification ensure quick assembly while providing a ridged, but attractive, structure that fits into any d├ęcor.
The 4" castors make it easy to move from room to room while the UL certification ensures you that it can be done with safety in mind.
Peerless SmartMount Universal Flat Panel TV Cart SR560M - cart
Cart
88.8 cm x 73.7 cm x 173.6 cm
Tilt
-5°
Rotation
360°
30 kg
Recommended Use
LCD / plasma panel
Recommended Display Size
32"-75"
Flat Panel Mount Interface
600 x 400 mm
Max Load Weight
68.2 kg
5 years warranty
88.8 cm
73.7 cm
173.6 cm
30 kg
AV Furniture
Cart
Recommended Use
LCD / plasma panel
600 x 400 mm
Shelf Qty
1
Cable Management
Integrated cable management
32"-75"
Tilt
-5°
Rotation
360°
Max Load Weight
68.2 kg
Swivel casters
Dimensions & Weight Details
RoHS, cULus
Limited warranty - 5 years
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: 91VQ 037390
Condition: Damaged stock - Item is new but has packaging damage
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not present or functional  This part of the stock item is present and in good condition  £80.49
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
