Maximize your flat panel experience by installing it truly flat against the wall with the industry's first universal in-wall mounting solution for up to 71" screens. Installation is quick and easy thanks to the mount's self-locating tabs that center the in-wall box snugly between standard 16" wood stud centers. View the flat panel screen in its no-profile home position, or extend the arm over 19" to watch it virtually anywhere else within the room. This mount holds screens so flat against the wall, it may even allow installations to meet ADA requirements.
- Peerless In-Wall Mount IM760PU - enclosure - for flat panel - high-gloss black
- Product Type
- Enclosure - in-wall mounted
- 78 cm x 49.3 cm x 55.5 cm
- 20.5 kg
- Recommended Use
- Flat panel
- Recommended Display Size
- 32"-60"
- Max Mounting Pattern Size
- 747 x 432 mm
- Max Load Weight
- 90.7 kg
- Material
- Cold-rolled steel
- High-gloss black
- 5-year warranty
- 78 cm
- 49.3 cm
- 55.5 cm
- 20.5 kg
- Material
- Cold-rolled steel
- High-gloss black
AV Furniture
- Enclosure
- Recommended Use
- Flat panel
- Placing / Mounting
- In-wall mounted
- 747 x 432 mm
- 32"-60"
- Max Load Weight
- 90.7 kg
- Scratch-resistant
- Limited warranty - 5 years
