Product
Peerless-AV In-Wall Box for SA730P/SA740P
Quicklinx: 9Z03WS00 Mfr#: IB40
Make the most of your flat panel experience by installing it truly flat against the wall with Peerless' IB40 In-wall box. Installation is quick and easy thanks to the mount's self-locating tabs that center the in-wall box snugly between standard 16" wood stud centers. View the flat panel screen in its no-profile home position, or extend the arm over 16" to watch it virtually anywhere else within the room. This mount holds screens so flat against the wall, it may even allow installations to meet ADA requirements.
Peerless In-Wall Mount IB40 - mounting kit
Mounting kit
Mounting Components
In-wall enclosure
41.3 cm x 9.5 cm x 36.8 cm
4.7 kg
Recommended Use
Flat panel
Recommended Display Size
Up to 40"
Max Load Weight
36.3 g
Material
Cold-rolled steel
High-gloss black
5 years warranty
41.3 cm
9.5 cm
36.8 cm
4.7 kg
Material
Cold-rolled steel
High-gloss black
AV Furniture
Mounting kit
Mounting Components
In-wall enclosure
Recommended Use
Flat panel
Up to 40"
Max Load Weight
36.3 g
Scratch-resistant
Limited warranty - 5 years
