The HP432-002 flat panel desktop swivel mount is designed as a functional and secure solution for desktop-mounted displays in hospitality applications. The mount directly bolts-down to the desktop surface for safety and security, with security screws that attach the display to the mount adaptor plate. With up to 30 degrees of swivel each direction, this mount provides a low-cost solution to fit a variety of needs and room configurations.
- Peerless Desktop Swivel Mount HP432-002 - mounting kit - for flat panel - black powder coat
- Product Type
- Mounting kit
- Mounting Components
- Swivel pipe, adapter plate, floor plate
- 22.2 cm x 10.2 cm
- Adjustable Height
- 42.6-57.2 cm
- 2.72 kg
- Recommended Use
- Flat panel
- Recommended Display Size
- 26"-37"
- VESA Mounting Interface
- 100 x 100 mm, 200 x 200 mm, 200 x 100 mm, 100 x 200 mm
- Max Load Weight
- 36 kg
- Material
- Fused epoxy
- Black powder coat
- 22.2 cm
- 10.2 cm
- Adjustable Height
- 42.6-57.2 cm
- 2.72 kg
- Material
- Fused epoxy
- Black powder coat
AV Furniture
- Mounting kit
- Recommended Use
- Flat panel
- 26"-37"
- Max Load Weight
- 36 kg
- Adjustable height, swivel base, scratch-resistant, security screws
