Peerless-AV Articulating Wall Mount For 22"-40" Displays
Quicklinx: 7G5KWS00 Mfr#: SA740P
Type: Mounting kit
Hurry, only 2 left in stock!
£100.54 ex VAT
£120.64 inc VAT
From any angle, this wall arm mount reflects remarkable form and function. Extending the display up to 20.18" (513mm) from the wall and allowing for a full 180° of side-to-side motion for viewing in any part of the room. Fine-tuning of the installation is simple with its side-to-side display leveling features that help achieve installation perfection. This Full-Motion Plus Wall Mount also provides display centering on the wall plate and integrates a cable management system, centering the display on the wall when retracted and organizing and protecting the cables at all times. Designed and built in the USA, this mount maintains the same brilliant look as the entire SmartMount 700 Series line of Full-Motion Plus Wall Mount and Pivot Wall Arm Mounts.
Peerless SmartMount Articulating Wall Mount SA740P mounting kit - Tilt & Swivel - for LCD display - black
Mounting kit (Tilt & Swivel) - wall-mountable
Mounting Components
Tilt/pivot wall mount, articulating wall mount
36.4 cm x 55.4 cm x 25.8 cm
Adjustable Depth
7.7-55.4 cm
Tilt
-5° to 15°
Swivel
-90° to 90°
Adjustments
Roll, tilt, swivel, depth
3.3 kg
Recommended Use
LCD display
Recommended Display Size
22"-40"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm, 200 x 200 mm, 200 x 100 mm
Max Load Weight
36 kg
5-year warranty
36.4 cm
55.4 cm
25.8 cm
Adjustable Depth
7.7-55.4 cm
3.3 kg
AV Furniture
Mounting kit
Mounting Components
Design
Tilt & Swivel
Recommended Use
LCD display
Placing / Mounting
Wall-mountable
Cable Management
Integrated cable management
22"-40"
Tilt
-5° to 15°
Swivel
-90° to 90°
Adjustments
Max Load Weight
36 kg
Finish
High gloss
Dimensions & Weight Details
38.7 cm x 29.2 cm x 10.6 cm / 4.24 kg
Limited warranty - 5 years
Type: Mounting kit
Brand: Peerless-AV
